• Need Support? Go to the Support Area!
  • Comment Bot v1.2.1 Released!
  • Social Media Bot v5.0.10 Released!
How to Port Social Media Bot Configuration of V4 to V5
#1
Note: v5 will be released soon!
As the release of v5 has some major changes, not everything can be ported over between version 4 and 5.
The following items can be ported from v4 to v5:
- Authentication file (your login info for the bot)
- Accounts saved on the bot
- Your ChromeData (cookies, logins, etc..)
- Tasks lists
The following items can not be ported from v4 to v5:
- Settings
To port your authentication file, simply copy the auth.dat file in the files folder over and rename it to auth.af (see this link if you don't know how to change a file extension)
To port your Accounts, open a client on version 5, go to the 'Accounts' tab and click 'Load'. At the dropdown in the bottom right, select 'All files (*.*)' and browse to the location of version 4 of the bot. Inside the files folder, select the acc.dat file and click open. The accounts should be loaded into the window.
To port your ChromeData, simply copy the ChromeData folder from the files folder of version 4 to the files/Client_# folder of version 5 (note that this folder is just created when clicking Open Client at the respective client number)
To port your Task List, open a client on version 5, go to the 'Tasks' tab and click 'Load'. At the dropdown in the bottom right, select 'All files (*.*)' and browse to the location of version 4 of the bot. Inside the files folder, select the default.dat file (or the task list file that you want to port) and click open. The tasks should be loaded into the window. (click Save Default if you want this task list to be your default task list)
Angel Donation Accepted:  Angel
BTC: 3L1nNEAXTHA8fDYhyXUU74kDFcgeFW7dPi
ETH: 0x6E7b0b8f984C432640cEE2CA65145f8C18F226df
PayPal: Click here
[-] The following 3 users say Thank You to Bollejef for this post:
  • DenDannie, MrJoel23, Nikita
Forum Jump:
Users browsing this thread: 1 Guest(s)
