Current suggestion list
Post any suggestions you have for the bot or website here.
Post by Bollejef »
EDIT: This topic is now closed
This is a list of suggestions that were already made, which will likely be implemented in the bot later (green = done):
- Add a delay type of task (vulkanes)
- Add an option to break for some time (Asp1re)
- Make the bot switch between methods when points per like/follow/.. gets lower than a certain treshhold (Asp1re)
- Support multiple accounts (Asp1re)
- Multi-Language (vulkanes)
- Proxy support (vulkanes)
Asp1re
Member
Member
Re: Current suggestion list
Post by Asp1re »
Heres the captcha idea:
There are multiple ways to approach it, but use google reverse image search :)
Post by Bollejef »
Asp1re wrote:
29 May 2017 11:04
Did you try it? I would be surprised if it works :-D And in most cases if you bot smart there is no need to solve a captcha :-p
Asp1re
Member
Member
Post by Asp1re »
Nope, cuz again, i emulated the webpage itself with ajaxes, which may be the reason why i got banned also :D
Also if you need any captcha solving, then i can try do it :) (googles recaptcha is probz too smart tho..)
I got only like 1-2 captchas in the reverse engineering process, before i got the idea.
Asp1re
Member
Member
Post by Asp1re »
Asp1re wrote:
29 May 2017 12:00
Re: Current suggestion listQuote Asp1re
by Asp1re » 29 May 2017 13:04
Bollejef wrote:
29 May 2017 11:13
Asp1re wrote:
29 May 2017 11:04
No, but i just had the idea in case i needed it.(i didnt) And yup... But i was stupid enough to use no delay except between action and verification :D. I would develop my bot further with apis, but since you have already a working bot, so i dont want to reinvent the wheel. And messing around with apis and their quotas is annoying. And the speed ur bot works on(browser speed) is enough, cuz my super fast one will be suspicious.
AND i got improvement to my first idea: It will like do all 10 point offers from all selected categories, then 9 point, then 8 point etc. So you have maximum amount of points. Also randomize it a bit, so harder to find a pattern. Also you should make a vps version of the bot, which will use browser ONLY to like/sub/etc.. otherwise just use straight requests. and then u need a pause feature, so like 2h run and 1h pause. And a multi bot feature would be nice, so u would have multiple accs, but then if u are using selenium, then u need to start messing with browser profiles and proxies, which is doable tho(to have multiple fb and other accs). I MIGHT do my bot vpn friendly without apis and make it work on selenium and headless browser.
Asp1re
Member
Member
Post by Asp1re »
I got a good one: multi browser support, like if i use opera then its pain in the ass to log in to sites again with chrome. and maybe some guys with less ram would use firefox :) it is easy to do with selenium :)
zeeshanfiaz
Member
Member
Post by zeeshanfiaz »
kindly add like4like bot and access key .... :) thANkyOu
Post by Bollejef »
zeeshanfiaz wrote:
06 Jun 2017 14:43
This will be added in about a month or so :-)
feikkan
Member
Member
Post by feikkan »
Hi, my suggestions is, on the like4like bot, it's about the bot, it tends to stop and say "completed tasks" when it arrives at https://www.like4like.org/user/bonus-page.php, "Claim you Prize "says on the page.
I suggest a script that makes you click on any of the elements of the captcha, then reload the page and continue with the process :D .
Post by Bollejef »
feikkan wrote:
16 Aug 2017 11:14
Thank you for your suggestion.
Right now the bot should click the first button of the bonus thingy. Could you tell me how the bot ended up at the bonus page (after clicking which element), as I expect this is a bug..
I will look in to it soon anyways, but it is difficult to fix, cus you only get the bonus page like 5 times/h :-D
Locked
