Dimension Bots - reCAPTCHA Bypass Chrome Extension!
All news & announcements will go here
DenDannie
Moderator
Moderator
Has thanked: 19 times
Been thanked: 4 times
Post by DenDannie » 21 Jun 2019 23:44
SAY GOODBYE NOW TO ALL RECAPTCHA's
We are proud to announce that we have found another free solution to bypass the annoying reCAPTCHA's
This extension will solve every captcha on websites with a form or a login window.
As you know and are used to we are always looking for the best (free) possibilities,
to keep the user friendliness of our bot program optimal, and the prices as low as possible.
We found another open source solution on the web and converted this into another extension, Say Hello to: Dimension Bots - reCAPTCHA Bypass.
Bollejef had already added 2 options to be able to bypass Captcha's: The Dimension Bots - Rate Limit Bypass chrome extension, this extension can only bypass the captcha on Cloudflare Rate Limit protected websites.
And the service DeathByCaptcha but this solution is not free.
ABOUT THE reCAPTCHA BYPASS EXTENSION
The reCAPTCHA Bypass Chrome Extension is a browser extension which helps you to solve difficult captchas by completing reCAPTCHA audio challenges using speech recognition, and is able to defeat reCaptcha V2 security via the extension that uses an audio recognition API to capture audio challenges as sound files. Then it uses speech-to-text technology to convert audio into text answers that are then inputted as text-based solutions to audio-based challenges used in reCaptcha V2.
Please note: It is not guaranteed that challenges are always solved, the limitations of the technology need to be considered, and solving more than a couple of reCAPTCHA challenges a day may lead to a temporary block regardless of using the extension.
HOW DOES THE reCAPTCHA BYPASS EXTENSION WORK?
● Challenges can be solved manual by clicking on the icon: Image at the bottom of the reCAPTCHA challange widget but the bot is also configured to do this full automatically.
Being an Entrepreneur, You learn more from your failures than from your successes, our greatest glory is not in never failing, but in rising up every time we fail, and success is no accident, it is hard work, perseverance, learning, studying, sacrifice, and most of all love what you are doing! Simple As That!
