Stuck at Loading UI
Post here if you found a bug or a problem.
enkin
Member
Member
Been thanked: 1 time
Stuck at Loading UI
Post by enkin » 11 Aug 2018 13:34
Hello, here a problem what i've got.
When i open bot, it loading before "Loading UI" text, then it stuck.
I read your FAQ about known problems, have installed java and net framework.
Can you help me with that? Thanks a lot.
Has thanked: 33 times
Been thanked: 38 times
Re: Stuck at Loading UI
Post by Bollejef » 11 Aug 2018 21:15
enkin wrote:
11 Aug 2018 13:34
Please join our Discord: https://discord.gg/k7QFPtw DenDannie will try to help your there as I'm not very available for the next days
enkin
Member
Member
Post by enkin » 12 Aug 2018 22:24
Problem solved, if you have the same problem -
https://java.com/en/download/manual.jsp
You need to choose and download 64-bit installer, for me it's worked!
Before that - uninstall your previous java version
Hope it helps someone!
