Page 1 of 1
Dimension Bots - Rate Limit Bypass Chrome Extension!
Posted: 12 Jan 2019 17:16
by DenDannie
SAY GOODBYE TO RATE LIMIT RECAPTCHA'S
We are proud to announce that we have found a free solution to bypass the annoying Rate Limit reCAPTCHA on websites with cloudflare protection,
As you know and are used to we are always looking for the best (free) possibilities,
to keep the user friendliness of our bot program optimal.
We found an open source solution on the web and converted this into an extension, Say Hello to: Dimension Bots - Rate Limit Bypass.
Bollejef had already added an option to be able to bypass Captcha's with DeathByCaptcha but this solution is not free.
The advantage is that DeathByCaptcha solves all type of Captcha's and the Rate Limit Bypass Extension only solves Captcha's on websites with reCAPTCHA Rate Limit protection.
The Rate Limit Bypass Chrome Extension creates 'Cookie Passes' when the user solves the reCAPTCHA Challenge manually, and can be used to bypass reCAPTCHA Challenges on websites that are protected by Cloudflare with Rate Limit protection - Web Application Firewall (WAF)
The 'Cookie Passes' will be stored by the extension for future use.
ABOUT THE RATE LIMIT BYPASS EXTENSION
When you start the Social Media Bot the bot will automatically open a chrome tab with the home page of Dimension Bots you will now see that a new extension is automatically added to chrome called Dimension Bots - Rate Limit Bypass.
● When you press on the icon from the extension, a menu will expand here you can find the necessary buttons to get along with the extension.
● The icon of the extension is currently gray, which means that the extension does not have any 'Cookie Passes'
● If the icon of the extension is blue-gray and the number 30 appears on the icon from the extension, that means that you have 30 'Cookie Passes' to be able to bypass 30 times the rate limit reCAPTCHA's on cloudflare protected websites example (AddMeFast)
'Passes' Here you can see the number of 'Cookie Passes' these cookies are used to automatically bypass the rate limit reCAPTCHA's on cloudflare protected websites example (AddMeFast)
'Get More Passes' When you press this button you redirect to a website called captcha.website this website uses Rate Limit Protection with ReCaptcha's like addmefast.com this option was added because addmefast does not always give 'Cookie Passes' when you solve the reCAPTCHA puzzle on their website.
(If this is in your case then go to captcha.website and solve the reCAPTCHA puzzle.)
'Log Redemption to Console' When you press this button the extension will send one bypass cookie to the rate limit reCAPTCHA's on cloudflare protected websites example (AddMeFast)
(This option is added because somthimes the extension don't bypass the reCAPTCHA automatic)
'Clear All Passes' When you press this button all 'Cookie Passes' will be removed from the extension. (not recommended)
'View on Forums' When you press this button you will be redirected to this post on the Official forum of Dimension Bots, here you can find more information about the Rate Limit Bypass Chrome Extension, and you can find more useful topics about our Social Media Bot.
Check also our other extension to bypass reCAPTCHA's used at logins on websites. Click here..
HOW DOES THE RATE LIMIT BYPASS EXTENSION WORK?
● Start the Social Media Bot, and browse manual with the bot browser that the bot opens
to: addmefast.com
You will probably arrive at the rate limit page of AddMeFast, solve the reCAPTCHA puzzle manually, Sometimes you have to solve the captcha several times, this is because google detects the automated extension of the Social Media Bot, if you have solved the reCAPTCHA correctly you will be redirect to the addmefast website, and the number 30 will appear on the icon of the Rate Limit Bypass Extension.
● If the number 30 does not appear on the icon of the extension, click on the icon of extension and then on 'Get More Cookies' you will be redirected to vedbex, solve this reCAPTCHA puzzle manually, if the number 30 still not appear on the icon, please Contact us.
Being an Entrepreneur, You learn more from your failures than from your successes, our greatest glory is not in never failing, but in rising up every time we fail, and success is no accident, it is hard work, perseverance, learning, studying, sacrifice, and most of all love what you are doing! Simple As That!
