• Need Support? Go to the Support Area!
  • Comment Bot v1.2.1 Released!
  • Social Media Bot v5.0.10 Released!
Dimension Bots - hCaptcha Rate Limit Bypass Chrome Extension! (Updated 2020/10/22)
#1
Credits to DenDannie for his original post
THIS EXTENSION IS UPDATED ON: 2020/05/21
● This Extension is now running smooth, you can still open a ticket if you notice an bug. Thanks!
● Cloudflare has stopped supporting Google's reCAPTCHAs and has switched to hCaptcha.
● The extension can now also solve hCaptcha's on websites without cloudflare (WAF) Protection,
(example: when registering accounts, at logins, or when filling in forms on websites.)
ABOUT THE RATE LIMIT BYPASS EXTENSION
The Rate Limit Bypass Chrome Extension provides users with the ability to create and sign cryptographically Cookie Passes for websites that supports our extension protocol. The extension generates passes containing cryptographically Cookie Passes that are signed by hCaptcha when a challenge is solved on any site using the hCaptcha service. These Cookie Passes are unblinded and stored by the extension for future use. When the user visits a site using hCaptcha and needs to pass the challenge (whether invisible, cloudflare protected websites (WAF) 'One more step' or via the 'I am human' button) they are redeemed automatically.
GET STARTED WITH THE RATE LIMIT BYPASS EXTENSION
When you start the Social Media Bot the bot will automatically open a chrome tab with the Bothome page of Dimension Bots you will now see that a new extension is automatically added to chrome called Dimension Bots - Rate Limit Bypass.
When you press on the icon: [Image: yYd0eEV.png] from the extension, an menu will expand with 5 options, here you can find the necessary buttons to get along with the extension.
● The first button you will notice is: 'Cloudflare' when you hover over the button you will see that the text: 'Get more passes!' appeared, When you press this button you will be redirected to a website called: captcha.website. (We'll go into more detail about this option later in this post.)
● The second button you will notice is: 'hCaptcha' when you hover over the button you will see that the text: 'Get More Passes!' appeared, When you press this button you will be redirected to a website called: hcaptcha.com. (We'll go into more details about this option later in this post.)
● The third button you will notice is: 'Log Redemption to Console' When you press this button the extension will send one 'Cookie Pass' to the hCaptcha picture puzzle challenge, (This option is added because sometimes the extension don't bypass the hCaptcha automatic)
● The fourth button you will notice is: 'Clear All Passes' When you press this button all 'Cookie Passes' will be removed from the extension. (Sometimes after some time it is possible that the cookie passes are outdated and they no longer work, click on this button if this is in your case.)
● The fifth button you will notice is: 'View on Forums' When you press this button you will be redirected to this post on the Official Forum of Dimension Bots.
HOW TO GET COOKIE PASSES TO BYPASS ADDMEFAST HCAPTCHA 'ONE MORE STEP'?
Start the Social Media Bot and Click on the icon: [Image: yYd0eEV.png] from the extension, an menu will expand with 5 options.
 The first button you will notice is 'Cloudflare' Click on this button if you need 'Cookie Passes' to bypass the hCaptcha picture puzzle challenge on cloudflare protected websites Like AddMeFast.com.
● After you clicked on this button you will be redirected to captcha.website, the first thing you will notice is that the icon of the Dimension Bots - Rate Limit Bypass extension has changed to gray and contains an blue pop-up with (!!![Image: jmrE5yo.png] which means that the extension is active but does not have any 'Cookie Passes' stored.
● The next thing you have noticed is that you ended up on a page with the title 'One more step' and an hCaptcha Picture Puzzle Challenge is displayed.
● Solve the hCaptcha Picture Puzzle Challenge manually, If you have successfully completed the captcha, a checkmark will appear in the white square box, the second thing you will notice is that the icon of the extension has changed to an blue-gray and contains an blue pop-up with the (30[Image: TEsrFTa.png] on the icon from the extension, that means that you have 30 'Cookie Passes' to be able to bypass 30 times the hCaptcha picture puzzle challenge on cloudflare protected websites Like AddMeFast.com (If the number 30 still not appear on the icon, create a ticket by clicking Here..)
HOW TO GET COOKIE PASSES TO BYPASS HCAPTCHA WHEN REGISTERING, LOGIN, ETC?
The Second button you will notice is 'hCaptcha' Click on this button if you need 'Cookie Passes' to bypass the hCaptcha picture puzzle challenge when registering accounts, at logins, or when filling in forms on websites.
● After you clicked on this button you will be redirected to hcaptcha.com, the first thing you will notice is that the icon of the Dimension Bots - Rate Limit Bypass extension has changed to gray and contains an blue pop-up with (!!![Image: jmrE5yo.png] which means that the extension is active but does not have any 'Cookie Passes' stored.
The next thing you will noticed is that you ended up on the home page from hcaptcha.com, scroll a bit down on the page till you see the box with the hCaptcha Picture Puzzle Challenge.
● Solve the hCaptcha Picture Puzzle Challenge manually, If you have successfully completed the captcha, a checkmark will appear in the white square box, you will now see that the icon from the extension has changed from gray and an blue pop-up with (!!!)[Image: jmrE5yo.png] to an blue gray and blue pop-up and contains the number (5[Image: 1zHJFCX.png] on the icon from the extension, that means that you have 5 'Cookie Passes' to be able to bypass 5 times the hCaptcha's when registering accounts, at logins, or when filling in forms on websites.
(Check also our other extension to bypass Google's reCAPTCHA by audio used when registering accounts, at logins, or when filling in forms on websites by clicking Here..)
Angel Donation Accepted:  Angel
BTC: 3L1nNEAXTHA8fDYhyXUU74kDFcgeFW7dPi
ETH: 0x6E7b0b8f984C432640cEE2CA65145f8C18F226df
PayPal: Click here
[-] The following 1 user says Thank You to Bollejef for this post:
  • DenDannie
Forum Jump:
Users browsing this thread: 1 Guest(s)
