• Need Support? Go to the Support Area!
  • Comment Bot v1.2.2 Released!
  • Social Media Bot v5.2.3 Released!
How to Bypass hCaptchas Using hCaptcha Own Accessibility Access
#1
ANOTHER WAY TO BYPASS HCAPTCHA's
Hi there, we are back with another free solution to bypass those annoying hCaptchas's.
This time we don't use an extension but we use hcaptchas own Accessibility Access.
You can read down below how the hCaptcha Accessibility Access works.
ABOUT HCAPTCHA ACCESIBILITY ACCESS
As you know Captchas are designed to stop bots by distinguishing them from people.
Visual tests are a convenient tool for this, but not everyone can solve a visual challenge.
For this reason hCaptcha have designed a simple painless alternative,
to let people bypassing their captcha service using their accessibility access cookie.
They are given an encrypted cookie that can be used several times per day, but must be refreshed every 24 hours via login.
When a challenge is presented to an accessibility user on any site using the hCaptcha service, they will automatically pass.
HOW DOES THE HCAPTCHA ACCESIBILITY ACCESS WORKS?
[font=Tahoma, Verdana, Arial, sans-serif]● [/font]The first step you gonna need to do is visiting hCaptchas official website and signing up as an accessibility user
via the accessibility signup page, enter your email adress and sign-up.
[font=Tahoma, Verdana, Arial, sans-serif]● [/font]The second step is opening your gmail account and find the email with this title:[font=Tahoma, Verdana, Arial, sans-serif] [/font]Instructions for using hCaptcha Accessibility
The third step is clicking on the big button in the email with the title: Get Accessibility Cookie
(You will be redirected to the official website from hCaptcha.)
The fourth step is clicking on the big button on the website from hCaptcha with the title: Set Cookie
(Afther you clicked on the button you should need to see the message: Cookie set.)
Please note: Somethimes the first time it doesn't set your cookie so you have to click another time,
Don't click more then 3 times as you get rate limted by hCaptcha and can't use this feature for couple of hours.
It is not guaranteed that challenges are always solved, the limitations of the Accessibility Access technology need to be considered.
its possible that if you try aggressive bypassing hCaptcha challenges using Accessibility Access cookie can lead to a temporary block regardless of using this feature.
INSTRUCTIONS FOR YOULIKEHITS YOUTUBE VIEWS
This is a small guide if you want to use the hCaptcha Accesibility Access together with YouLikeHits YouTube views task,
As the hCaptchas limitations of the Accessibility Access technology you get really fast rate-limited,
if you run unlimited tasks where hCaptcha puzzle are presented.
(Example on the Social Exchange site YouLikeHits Task: YLH YouTube Views Task.)
That's why we suggest to run max Task from 25 minutes of YouTube views on YouLikeHits and add a minimum of 60 minute brake after doing the same tasks again.
ofcourse you can also fulfill the 60 minute brake by adding other tasks such as YT Likes, YT Subs, YT Comments, Pinterest repins etc.
The reason for this brake is because YouLikeHits shows an hCaptcha that you have to solve after you watched 25 videos
and because this feature quickly becomes rate limited, if you solve too many captchas within 1 hour you will be blocked for a longer period of time.
And thats it folks, this is another way to beat hCaptchas using their own Accesibility Access Awesome right?
if you find something usefull you want to share, you can create a post on the forums so that we can all benefit from it.
see you next time in a new post.. Cheers!  Big Grin
<<WE WILL SUPPORT THIS FEATURE SOON IN THE SOCIAL MEDIA BOT SOFTWARE TO AUTOMATE THIS PROCEDURE>>
[-] The following 1 user says Thank You to DenDannie for this post:
  • Bollejef
Forum Jump:
Users browsing this thread: 1 Guest(s)
