YtMonster - Printable Version +- Dimension Bots - Forum (https://dimensionbots.com/forum) +-- Forum: Dimension Bots (https://dimensionbots.com/forum/forumdisplay.php?fid=5) +--- Forum: Report a bug (https://dimensionbots.com/forum/forumdisplay.php?fid=8) +--- Thread: YtMonster (/showthread.php?tid=150) |
YtMonster - MrJoel23 - 11-20-2020 For some reason I am not getting any points from YTMonster. I know they updated their system and stuff and now it requires you to wait a certain amount of time before you close the page while liking videos. Which I adjusted in the settings and it works fine. But the problem i'm having is not getting any points even with the correct amount of time before the page closes. I'm assuming its because the youtube video doesn't automatically play when the page opens but I am not sure. If you can get back to me thanks! RE: YtMonster - Bollejef - 11-20-2020 I will check it, but I don't recommend using YTMonster, their site is one of the worst working ones. RE: YtMonster - MrJoel23 - 11-20-2020 (11-20-2020, 06:11 AM)Bollejef Wrote: I will check it, but I don't recommend using YTMonster, their site is one of the worst working ones. I stopped using YTMonster for a long time because they were horrible but I wanted to see if anything changed these days but what would you recommend for YouTube? And I think I found the solution of the problem I said it in the shoutbox but ill copy and paste it here "I figured out the ytmonster problem if you close out the tab before the site does it for you. You wont get the points. You would have to verify the like without closing out the youtube tab" Thank you! RE: YtMonster - Bollejef - 11-21-2020 Tried that, but they aren't closing any window lol I use LikesTool for views and Like4Like for subs. Currently coding ytmonster.ru, which seems to work pretty well. RE: YtMonster - Nikita - 12-03-2020 Ytmonster is a bad site and now it is dead . liking system is way broken and u need to add a youtube account and Start liking throw that account to be counted and 70% of the likes don't get counted . and the likes list should be set to public . |
