Dimension Bots - Forum
fix this please - Printable Version
+- Dimension Bots - Forum (https://dimensionbots.com/forum)
+-- Forum: Dimension Bots (https://dimensionbots.com/forum/forumdisplay.php?fid=5)
+--- Forum: Report a bug (https://dimensionbots.com/forum/forumdisplay.php?fid=8)
+--- Thread: fix this please (/showthread.php?tid=147)
fix this please - matiirodriguez - 11-19-2020
Hello, I have been subscribed to socialmedabot for months and I have a series of problems.
I have never been able to use the program for addmefast because it bans me within minutes and because it doesn't pass the captchas. I also have problems with the like4like.org login, I have the username and password correctly set, but it does not log in automatically. Please, I need a solution to the addmefast problem.
RE: fix this please - Bollejef - 11-19-2020
If you can't solve the AddMeFast captcha: Click the Rate Limit Bypass extension -> Clear all passes. Click on Cloudflare -> Get more passes, finish the captcha there, it will get you 30 passes and will allow you on AddMeFast. If it didn't work directly, retry until it does.
Once they flagged your IP, you will never be able to use them from that IP btw
For the Like4Like problem, I'm gonna need a video.
