Can't login in google - Printable Version +- Dimension Bots - Forum (https://dimensionbots.com/forum) +-- Forum: Dimension Bots (https://dimensionbots.com/forum/forumdisplay.php?fid=5) +--- Forum: Report a bug (https://dimensionbots.com/forum/forumdisplay.php?fid=8) +--- Thread: Can't login in google (/showthread.php?tid=1018) |
Can't login in google - Juliahanavey - 02-01-2025 "Try using a different browser. If you’re already using a supported browser, you can try again to sign in." Always getting this when try to login. User-Agent extension is not working for me. Help pls.... I've just read all previous threads and couldn't fond a solve.. RE: Can't login in google - Bollejef - 02-02-2025 Hi, Using the extension, it usually takes between 1-10 tries before a user agent is found that works to login. If it still doesnt work, there are 2 other options: - Login on an original Chrome under a new profile and then copy the whole profile folder over the ChromeData folder of the bot (always works) - Login in on an original Chrome and use something like EditThisCookie to copy all cookies from the original browser to the bots browser (has mixed success) Regards, Bollejef RE: Can't login in google - Juliahanavey - 02-02-2025 - Login on an original Chrome under a new profile and then copy the whole profile folder over the ChromeData folder of the bot (always works) ok, thanks for help. This option is work for me BUT if i set in the task list "Change YouTube account" - it doesn't work.. i see this message again "Try using a different browser. If you’re already using a supported browser, you can try again to sign in." Is any option to fix that? Or i can use only one acc? |
